Don't Miss Out!! Attend IMTS 2008, the largest manufacturing trade show in North America, Sept. 8-13, Chicago. See faster, more precise machines; live demos; cutting tools for virtually any material; finishing technologies; automation systems; quality instruments and manufacturing software. Reduce cycle times and increase productivity. Sign up TODAY!www.imts.com.
Articles |
A semi-synthetic that does it all |
Here is a new high-performance, high-lubricity semi-synthetic metalworking fluid that can increase productivity, lower tool costs and improve tool and part finish. And its rinse behavior leaves parts and machines clean and helps to reduce coolant consumption. Read the full story here |
Indexable drill simplifies operations |
An indexable drill has been introduced with adjustability of 0.200 in. (5.1 mm) on diameter, eliminating the need for specials and/or subsequent boring operations. The indexable drill is available in diameters from 1.75 in. to 4.0 in., with 12 different holders and three lengths to 4.5-times diameter. Read the full story here |
New diamond dressing technology improves cutting |
A new hybrid bonding technology for rotary diamond products has been developed that combines the toughness of metal bonding with the natural porosity of a vitrified bond structure, comparable to porosity found in vitrified CBN grinding wheels. Read the full story here |
High-speed cutter for stainless sheet |
A new line of tools have been developed that are capable of running at high spindle speeds while providing good tool life to solve the problem of cutting stainless steel on a high-speed CNC router. The combination of cutting geometry and coating allows stainless steel to be routed for sign, exhibit, and general sheet applications. Read the full story here |
Tools with variable pitch reduce chatter |
New cutters with a variable pitch flute pattern are designed to eliminate harmonic vibration, the main source of chatter. The manufacturer said the tools enable faster cutting and finer finishes in rough or finish slotting, shoulder milling and cavity milling and result in longer edge life because of reduced chatter. Read the full story here |
New grade for turning hard materials |
This new insert grade that provides increased speeds, high metal removal rates and process stability in steel turning applications may be just what you’re looking for. The grade offers an extended performance range, from roughing to medium- and semifinishing and is designed for turning hard materials where high cutting temperatures are generated. Read the full story here |
Featured Advertiser |
Benz is your innovative partner for all applications and challenges of the modern cutting industry. Sixty years of leadership in aggregate technology. Click here to visit our website.
Used Equipment Directory UED is the most comprehensive and best-known directory of available used equipment including manufacturing, material handling, electrical and chemical process. Sign up today to receive UED monthly by mail or email. Can't wait? Visit www.ued-ed.com to see the latest issue.
Hot Products |
Robotmaster is a CAD/CAM off-line programming software tool for 6-8axis robots. Some benefits of Robotmaster are: creation of simple or complex robot trajectories accurately without teaching points; single solution compatible with multiple robot manufacturers. Robotmaster is ideal for all applications including Trimming, De-burring, De-flashing, Dispensing, Mold Machining, Spray Coating etc. ... www.robotmaster.com
Make BIG Kaiser your most productive stop at IMTS this year. Stop by for one of the Precision and Performance Seminars at IMTS booth F-2114. Starting every half hour from 11:00 a.m. - 4:30 p.m., Monday through Friday, the Seminars highlight the latest technology in boring tools, tool holders, cutting tools, presetters and workholding technology. For more information visit, www.bigkaiser.com/imts.
Tool Shop Optimization:
Concurrent Engineering for Today's Machine ShopLive Webinar: August 27, 2008 @ 2:00 pm ET Applying concurrent engineering processes to design and manufacturing can help toolmakers increase productivity and shorten product delivery times—improving responsiveness to customers and your company's bottom-line results.How can you make concurrent engineering a success at your machine shop? Attend this free on-line seminar and learn:
AM Webcasts |
- What is Concurrent Engineering?
- What is it NOT?
- How to make Concurrent Engineering the KEY to improving your delivery times
Now Available On Demand
5 Key Strategies For Reduced Cost and Increased Profitability Striving to reduce costs and increase profitability while remaining competitive is no easy task. Epicor Manufacturing talks about ways to plan, schedule, execute and monitor your manufacturing operations – from raw materials to final product – to develop your highest level of flexibility and agility, and to make your operations more competitive. Watch Now!Sponsored by: EPICORBenchmarking at IMTSAmerican Machinist conducted its third annual Benchmark Survey of American Machine Shops between February and April of this year. American Machinist, reviews the results of this third annual survey, and talks about what the data means and how shops can use the data to make plans for this year's IMTS. Watch Now!
AM Workshop |
The only workshop that focuses on the business side of running a machine shop. The 2008 Machine Shop Workshop is an intensive 2-day event featuring peer presentations, best-practices and an emphasis on solving your real-world problems. Your registration includes:
- Tickets to the "Best Machine Shops" award banquet
- A free copy of the new "Benchmarks for Machine Shops" handbook
- Plus breakfast, lunch and dinner buffets.
Announcements |
American Machinist Launches New Internet Forum The American Machinist Forum is a place to share thoughts, ideas and best practices for machine shops. The focus is on making machine shops competitive, efficient and flexible enough to compete in a global environment. You'll find discussion about manpower, use of automation and technology, creative uses of machine tools and a whole lot more. So sign up now and jump in. Click Here
AM Machine Tool Theater |
New Machine Tool TheaterAmerican Machinist announces launch of Machine Tool Theater. Watch videos about machining and machining equipment. You'll see faster, more precise machines; cutting tools to process virtually any material; finishing technologies; automation systems; quality instruments and manufacturing software. You'll see how to reduce cycle times and increase productivity. Watch Videos Now
Digital Edition |
Now you can get the latest edition of American Machinist delivered directly to your PC. Digital editions allow you to page through articles, click through hotlinks for direct advertiser websites, send emails to authors and other contacts, zoom, print or send to a friend. Sign Up Today!
Copyright© 1998-2008 Penton Media, Inc. 1300 E. 9th St. Cleveland, OH 44114. All rights reserved. Penton Media's Privacy Policy To learn how to reach this newsletter's thousands of qualified readers, e-mail Christian Webb or call 216.931.9501. To reach this newsletter's editor, email Bruce Vernyi or call 216.931.9240. You are subscribed as #email#. To visit our subscriber area or to manage your account,click here. To unsubscribe click here.
