Fiber-pumped markers
The ProWriter F20 is a fiber-pumped, 20-W laser marker with a pumping technique for using telecom-grade diodes.
June 8, 2005
The ProWriter F20 is a fiber-pumped, 20-W laser marker with a pumping technique for using telecom-grade diodes. It requires no special electrical connections or external cooling because it operates on typical house current. A compact design allows it to fit into production lines where space is limited. The marker is protected by a two-yr warranty.
Baublys Control Laser
Orlando
controllaser.com
