Www American Machinist Com Content Site304 Articles 07 01 2010 86085 Indexpng 00000058725
[IMTS Preview] Index Corp. for Automatic Lathe, Production Machine
July 27, 2010
Index Corporation will present the new TRAUB TNL18 sliding headstock automatic lathe and its variant, the TNL18P production machine. The TNL18 can be changed over in minutes to produce precision parts with or without a guide bush for long or short ...
Index Corporation will present the new TRAUB TNL18 sliding headstock automatic lathe and its variant, the TNL18P production machine. The TNL18 can be changed over in minutes to produce precision parts with or without a guide bush for long or short parts from bar up to 20mm diameter. Up to three tools can be on the part at once. The machines are ideal for medical component machining, delivering precision and qualified surface finish in a single operation.
The tool capacity of the TNL18 can be increased to as many as 54 tool places through dual- and multi-holders, extending productive times. The high-precision, fast turret indexing enables a very fast chip-to-chip time of 0.3 s. Both variants make use of the new TRAUB compact shaft system: an improved system for high-precision mounting of tool holders in the turret.
The lathe can quickly be changed over for use with and without a guide bush for long or short parts. The extremely long Z-travel distance of the headstock ensures the proper positioning of the main spindle, either for turning with a guide bush or without. In the standard design, the powerful main spindle is equipped with a C-axis and provided with either a direct drive with high dynamic response or a belt drive (TNL18P) and high torque in order to achieve large cutting volumes.
Simultaneous machining with multiple tools ensures high productivity levels by both machines; up to three tools may be used simultaneously on two spindles. The TNL18P production machine differs from the TNL18 variant in that the Y-axis motion of the upper turret is mapped by interpolation of the X/C/H axes, permitting contour milling, and reliable off-center, axially parallel drilling.
Visit IMTS Booth #S-8136
