Mold Polishing/Finishing Handpiece
Sept. 19, 2006
Engis Corp., Wheeling, W.Va. (www.engis.com), North American distributors of the Di-Pro polishing/finishing system manufactured by Diprofil in Sweden, says the polishing/finishing system optimizes user efficiency and comfort. It weighs 1.98 ...
Engis Corp., Wheeling, W.Va. (www.engis.com), North American distributors of the Di-Pro polishing/finishing system manufactured by Diprofil in Sweden, says the polishing/finishing system optimizes user efficiency and comfort. It weighs 1.98 lb (0.9 kg), has a maximum speed of 10,000 rpm with a stroke length of 0.023 in. (0.6 mm). The system is ergonomically designed for extended use with a variety of drive systems and includes an integrated air motor, flexible shaft (slip-joint or ball-joint), integrated micromotor and connections for other common micromotors.
Engis says the Di-Pro system works best with Diprofil diamond tools including the DLA, DLE, DLF, DLM and DBE types, and with Diprofil lapping and polishing tools.
