Weiler Corporation
Oct. 10, 2007
Weiler Corporation says its new AL-tra CUT discs are specially designed for superior grinding performance on aluminum because the discs resist loading when grinding aluminum, ensuring constant contact with the work surface and dramatically ...
Weiler Corporation says its new AL-tra CUT discs are specially designed for superior grinding performance on aluminum because the discs resist loading when grinding aluminum, ensuring constant contact with the work surface and dramatically increasing performance. Available in 4.5 in. and 7 in. sizes with grit sizes ranging from 36 to 120.
www.weilercorp.com
