Americanmachinist 532 82041metalcompa00000054042
Metal Compactor
Sept. 5, 2008
Kurt Manufacturing (www.kurtchip.com) will exhibit its new 45 metric ton Chipmunk metal compactor briquettor. The company said this new model and its larger, 125-metric ton model, are the most energy efficient, high output systems for ...
The company said this new model and its larger, 125-metric ton model, are the most energy efficient, high output systems for compacting aluminum and steel/ductile iron chips.
Both Chipmunk models use a hydraulically driven infeed auger that separates most unwanted solids from chips prior to the compacting cycle.
Both Chipmunk models deliver up to 8:1 compaction ratio and reclaim expensive cutting fluids. The Chipmunk systems compact ferrous and non-ferrous chips into dense 3 in. X 1… in. briquettes for recycling.
Latest from Shop Operations
BiancoBlue | Dreamstime
Divinesky27 | Dreamstime
Warut Sintapanon | Dreamstime
Spaxia | Dreamstime
