The Lincoln Electric Co.
Cleveland
lincolnelectric.com
Inverters handle power variations
Miller Electric Manufacturing Co.
Appleton, Wis.
millerwelds.com
Monitor cooling flow
Universal Flow Monitors Inc.
Hazel Park, Mich.
flowmeters.com
Power supply runs on 110 or 230 V
Orbimatic GmbH
Peterborough, U.K.
orbimatic.co.uk
Control plasmacutter current
ESAB Welding and Cutting Products
Florence, S.C.
esabna.com
Machine showcases tilting rotary table
Hermle Machine Co.
Franklin, Wis.
hermlemachine.com
High-speed machining
Mitsubishi EDM/Laser
Wood Dale, Ill.
mitsubishiworld.com
Wire EDM with digital generator
Charmilles
Lincolnshire, Ill.
charmillesus.com
Flexible grinder control
OpenCNC Grinder packages consist of hardware, software and documentation capability. Programming features include 11 wheel-dressing routines, eight grinding sequences, advanced grinding-wheel-offset tools, and an on-line help system. Each part program may contain as many as 20 grinding sequences. For control retrofitting, the package comes with wiring diagrams, documentation, and prewritten PLC logic.
MDSI
Ann Arbor, Mich.
mdsi2.com
Tool grinder puts on a show
Rollomatic Inc.
Mundelein, Ill.
rollomaticusa.com
New handwheels
Carr Lane Mfg. Co.
St. Louis
carrlane.com
Real-time process monitoring
ATAM Systems Inc.
New Albany, Ohio
atam.com
Quick-working control
GE Fanuc Automation Americas Inc.
Charlottesville, Va.
gefanuc.com
Laser marker
Telesis
Circleville, Ohio
telesis.com
Inspect tiny openings
Gradient Lens Corp.
Rochester
gradientlens.com
Software for small shops
Lilly Software Associates Inc.
Hampton, N.H.
visualjobshop.com
New features for multispindle
DeVlieg Bullard II Inc.
Twinsburg, Ohio
nationalacme.com
Profile system has inch dimensions
With inch-dimension capability, the iSeries of the IPS modular aluminum profile system includes 21 profiles, plus a range of fasteners and accessories. There are plenty of smooth-face extrusions. The IPS system is useful in constructing enclosures, machine building, industrial automation, material handling, and as machine safety guards.
Parker Hannifin Corp.
Cleveland
parker.com
Vertical bandsaws
A Tannewitz vertical bandsaw cuts tough alloys such as stainless, tool, and mild steel; brass; sheetmetal; aluminum; and plastics. There are seven models with 16, 20, 28, or 40-in. throat capacities and two speed ranges. Hydraulic tables are available for the 20, 48, and 40-in. saws.
Tannewitz Inc.
Jenison, Mich.
tannewitz.com
Machines extend coolant life
Vanson HaloSource
Redmond, Wash.
coolantxtender.com
