Www Americanmachinist Com Content Site304 Articles 09 01 2004 Neweq0100png 00000002005
Spindles tackle mold milling
Sept. 1, 2004
Type SC 55104 3.94-in.-diameter spindles tackle accurate mold milling with high metal removal. They use HSK-32 tapers and work up to 40,000 rpm with permanent-grease bearings. The manufacturer reports the Type SC 55104s have the highest bearing stiffness
Type SC 55104 3.94-in.-diameter spindles tackle accurate mold milling with high metal removal. They use HSK-32 tapers and work up to 40,000 rpm with permanent-grease bearings. The manufacturer reports the Type SC 55104s have the highest bearing stiffness in their class — 150 nµ — for generating good surface finishes.
The Precise Corp.
Racine, Wis.
precise-corp.com
