A lightweight column on the FH630 HMC reportedly results in quicker response times without compromising rigidity. The machine's cast bed supports rapid-axis movement while maintaining constant accuracy over time. Dual ballscrews and drives in each axis contribute to acceleration rates up to 1,890 ipm with 0.5-G acceleration. The FH630 sports a 50-taper, 6,000-rpm, 4.33-in.-diameter spindle for heavy cuts.
Toyoda Machinery USA
Arlington Heights, Ill.
toyodausa.com
