ValMill V595 extended-flute end mills provide long options. Their multiple deep-cutting inserts rough and finish grooves, slots, and cavity side walls, along with other peripheral and end-milling applications. Square 90° configurations eliminate many secondary operations. The cutter/insert design provides good chip evacuation and through-coolant for fine surface finishes. ValMill end mills also do fast insert index/changeovers.
Valenite LLC
Madison Heights, Mich.
valenite.com
