The PTC150-G with a 150 mm (6 in.) chuck, a gang-type slide with space for up to six toolblocks and optional 8-position turret. This 2,500 kg (5,500 lbs.) machine comes with a 7.5 kW (10 hp), 6,000 rpm, A2-5 spindle with a 45 mm (1.75 in.) through hole.
The PTC150 is a 3,000 kg (6,600 lbs) machine with 150 mm (6 in.) chuck, 11 kW (14.7) hp, 6,000 rpm motor and an A2-6 spindle with a 70 mm (@.8 inch) through hole.
The PTC200 4,540 kg (10,000 lbs) machine with 200 mm (8 inch) chuck, 12-positiion turret, 15 kW (20.1 hp), 4,500 rpm motor and A2-6 spindle with 70 mm (2.8 inch) through hole. A powered turret providing driven tools is optional.
The PTC250 5,800 kg (12,760 lb) machine with an 18 kW (24.8 hp), 3,500 rpm motor, A2-8 spindle with 90 mm (3.5 inch) through hole, standard 250 mm (10 inch) chuck and optional 300 mm (12 inch) chuck. A 12-position turret is standard and a powered turret is optional.
