Americanmachinist 1200 84464tappedtype00000056789
Tapped-type leveling mounts
June 22, 2009
Tapped-type NY-LEV nylon base machinery leveling mounts from J.W. Winco Inc. deliver a quality and economical solution to leveling and height adjustment needs by swiveling 15 degrees in all directions. Manufactured from hex bar ...
Tapped-type NY-LEV nylon base machinery leveling mounts from J.W. Winco Inc. deliver a quality and economical solution to leveling and height adjustment needs by swiveling 15 degrees in all directions. Manufactured from hex bar stock, the tapped sockets of the mounts will not separate from the nylon base.
Available in both steel and stainless steel with or without lag holes, the leveling mounts have glassfilled nylon plastic bases and non-skid elastomer rubber pads that resist many organic acids, most chemicals, alkalines, salt, water and corrosion.
