Performance pump
Oct. 13, 2009
Made for 24/7 operation, the JetPlex ultrahigh-pressure waterjet pump from Flow International Corp. features a special design and high-quality components for longer intervals between maintenance cycles. The direct-drive pump has no hydraulic system, ...
Made for 24/7 operation, the JetPlex ultrahigh-pressure waterjet pump from Flow International Corp. features a special design and high-quality components for longer intervals between maintenance cycles. The direct-drive pump has no hydraulic system, which also makes them easy to maintain.
Flow equips the JetPlex with its special Automatic Control Valve, or Pac-V, technology that ensures quick reaction when changing operating pressure or opening and closing the flow of water through the cutting nozzle. The Pac-V is also easier and more reliable than designs that use bypass valve or dual-orifice designs to control water flow. In addition, the technology allows for the use of a wide range of orifice sizes for tackling challenging and diverse applications.
