Americanmachinist 1876 80887ybm7tandyb00000053251
Accurate and stable machines
June 11, 2008
The YBM7T and YBM8T, built for optimum accuracy and speed in small and mid-size parts and die-mold machining, are Yasda Precision America Corp.’s (www.yasda.com) latest editions to its YBM series of Precision Centers. A special arrangement of ...
A special arrangement of twin ballscrews and hybrid box-type guideways positioned on either side of the machine spindle heads deliver increased stability and accuracy, along with rigidity and high damping performance against forces generated during high-speed machining.
In addition, the company’s own spindle bearing preload self-adjusting system adjusts to a large preload for low-speed heavy cutting and conversely to heat generated by higher spindle speeds. A diaphragm coupling, co-axially connecting the spindle cartridge and motor, results in accurate spindle rotation at full speeds.
