[IMTS Preview] New WIDIA Inserts for WIDIA Victory M1200 Mill Series
New WIDIA-brand inserts for the WIDIA Victory M1200TM face mill series are especially designed to provide excellent results in aluminum when machining the most common milling operations like roughing, semi-finishing, and finishing. Also applicable to other non-ferrous materials, these new inserts are being introduced at the WIDIA booth at IMTS 2010.
Two separate geometries are being offered, and any shop milling aluminum and non-ferrous materials will benefit from using these two inserts in conjunction with the WIDIA Victory M1200 milling cutters. Their combination of toughness and wear resistance allow faster feed rates, and the 12 cutting edges per insert, as well as the reduced power consumption resulting from the free-cutting geometry, make them very economical to use. They are ideally suited for the majority of machining centers in use today using moderate to high spindle speeds and regular depths of cut .
The LDJ geometry featuring optimized rake angles is specifically designed to be free cutting. This insert with 12 cutting edges is available in two grades, THMU and a TiB2-coated TN6501. Both inserts are peripherally ground and feature highly polished rake surfaces. THMU is the first choice for most non-ferrous materials while the TN6501 with its TiB2 coating offers even freer cutting in high silicon aluminum (>8%) due to the coating’s extremely low coefficient of friction.
The LDJ3W geometry is a wiper-style geometry. It features 3 RH cutting edges and 3 LH cutting edges and is offered in the THMU and TN6501 grades also.
Visit IMTS Booth # W-1452
TAGS: IMTS 2010
Comments
Publish
