Hydraulic Workholding Yields High Accuracy
Automotive supplier slashes set-up times, and still hits targets.
Southland CNC in Cornelia, Ga., is a Tier Two supplier of automotive components to domestic and transplant automakers — primarily sand-cast aluminum parts. Established 19 years ago with a single machine in president/owner Keith Armour’s garage, it has 30 employees now using 21 high-capacity machining centers.
Samples of sand-cast aluminum parts in hydraulic fixtures at Southland CNC, to be finish machined for Tier One automotive customers.
Southland machines various parts that include production runs of very high volumes, and other production runs of relatively low volume. It uses dedicated hydraulic clamping fixtures on Okuma Howa vertical machining centers for its high-volume production runs, because these fixtures decrease production time significantly, which makes the fixturing highly cost-effective. The dedicated hydraulic fixtures also provide clamping pressure that is consistent and repeatable, which improves machining accuracy.
According to Armour, the typical tolerances are held to 20 microns true position, with critical dimensions to +/- 6 microns, which he credits largely to the hydraulic fixturing supplied by advanced machine & engineering. Because low-volume production runs do not justify dedicated fixturing, Southland uses manual fixtures, when appropriate, because it is an adaptable approach with a lower cost of acquisition.
Currently, Southland has four horizontal machining centers that use hydraulic tombstone fixturing, and three vertical machining centers that use hydraulic tombstone fixturing, all designed and built by AME. These fixtures are dedicated to high volume production of single parts or single families of parts.
Flexible hydraulic fixturing devices
Flexible hydraulic fixturing devices from Advanced Machine & Engineering are used to expedite set-ups on vertical and horizontal machining centers at Southland CNC.
Southland chose AME to provide its first tombstone hydraulic fixture because its offering was competitively priced and custom designed to the shop’s production needs. Delivery, which was very important to Southland’s production scheduling, was significantly better than any other designer/supplier, according to Armour. The first AME fixture specifically replaced the customer-supplied fixturing that Southland had been using, which the shop determined was not providing the efficiency needed to meet the cost and schedule targets for the high-volume production run.
The advantages of the AME-designed fixture included reduced load/unload time, reduced cycle time, reduced scrap rates, and error-free loading. The initial application of the fixture reduced Southland’s cycle time by over 50%, which allowed Southland to meet the high-volume order without additional machines. According to Armour, production of one bearing plate for a supercharger assembly has increased from 50 units to 110 units per day with the same superior tolerances and a 1.67 Cpk, critical to the Six Sigma conformity for its major automotive customers. All finished parts are verified for accuracy on Southland’s in-house CMM.
The fixture, which provides automatic clamp and release, is designed with locating dowels to ensure error-free handling. Each component to be machined is handled only twice: once as it is loaded into the fixture, and a second time as it is unloaded. Because the fixture is a windowed fixture, the component is completely machined on all four sides without additional handling. On the vertical machining centers, typically a second loading pallet is used to mount workpieces while another fixture is running in the machine.
full-service automotive machine shop
Southland CNC is a full-service automotive machine shop running a range of products, mainly aluminum sand castings, in high-volume and low-volume sequences.
Armour added that the AME-produced fixturing has been very reliable. One fixture has been in operation 20 hours per day, five days a week for more than seven years, and without a single problem. Because of this reliability, and because of the cooperation and innovation AME has provided, Southland added a second fixture for the vertical machining centers, and a fixture dedicated to horizontal machines.
“The fixture configurations we designed for Southland include cast tombstones as well as welded tombstones,” explained Alvin Goellner, manager of AME’s Fixturing Group. “Depending on the intended use for the fixtures, they were provided with external surface mounted hydraulics as well as internally cored hydraulics.”
One particular aluminum casting, a bearing plate for a supercharger, measures 8×4×1.5 in. (L×W×D.) Requiring two machining operations per side, the workpieces are loaded in less than 20 minutes on a second fixture, using the secondary pallet on the VMC. Southland produces approximately 30,000 of these part annually for a Tier One supplier to Jaguar, BMW and Mercedes.
“The fixture was designed specifically for this part, though it’s flexible enough to allow us to use it for other jobs,” according to Keith Armour. “AME had a very short turnaround time, plus their knowledge of workholding and the components they selected were all first-rate.
“We have experienced zero downtime because of the fixturing they supplied us for this particular part,” he continued. “Although we tweak the rest pads for enhanced accuracy, that’s normal with the machining centers we use.”
He also noted the design and development work was done via CAD drawings and the completion of the entire project was done on schedule and at the quoted price. “When we began to go from 50 parts per day to 110 or better, with absolutely no loss of accuracy and finish quality, we knew we’d made a wise choice,” Armour said.
Comments
Publish
